projects:bolt:index [2019-10-03 14:54] tobias [Current firmware status notes (2019-10)] |
projects:bolt:index [2019-12-09 15:17] tobias [Specification] |
Line 5: | Line 5: | ||
====== Crazyflie Bolt ====== | ====== Crazyflie Bolt ====== | ||
- | The Crazyflie Bolt is a Crazyflie 2.X compatible flight controller for brushless builds. It is intended to have the strengths of the Crazyflie 2.1 but in a slightly bit bigger package. | + | The Crazyflie Bolt is a Crazyflie 2.X compatible flight controller for brushless builds. It is intended to have the strengths of the Crazyflie 2.1, but in a slightly bit bigger package. |
+ | ===== Board renderings ===== | ||
+ | The size of the board is 36mm x 35.4mm and the holes are M3, located at the common 30.5mm square, to fit most frames. | ||
- | The size of the board is 36mm x 35.4mm and the holes are M3, located at the common 30.5mm square, to fit most frames. | ||
- | Please see the shop product page for full specification | + | Please see the [[https:// |
===== Features and differences from Crazyflie 2.1 ===== | ===== Features and differences from Crazyflie 2.1 ===== | ||
Line 30: | Line 33: | ||
===== Power ===== | ===== Power ===== | ||
- | The Bolt contains a power distribution board (PDB) but it is a bit limiting. | + | The Bolt contains a power distribution board (PDB) but it is a bit limiting. |
===== Schematics ===== | ===== Schematics ===== | ||
Line 48: | Line 51: | ||
* If higher then 8A is wanted only connect the signal wires from the ESC connectors to the ESC. Preferably still power the Bolt control board via the battery connector so the battery voltage can be monitored. | * If higher then 8A is wanted only connect the signal wires from the ESC connectors to the ESC. Preferably still power the Bolt control board via the battery connector so the battery voltage can be monitored. | ||
===== Configuration ===== | ===== Configuration ===== | ||
The Crazyflie firmware will automatically detect that it is running on a Bolt and activate the right modules. However some of the configurations still has to be done during compile time and making them run time configurable is currently work in progress. | The Crazyflie firmware will automatically detect that it is running on a Bolt and activate the right modules. However some of the configurations still has to be done during compile time and making them run time configurable is currently work in progress. | ||
Line 54: | Line 59: | ||
* Different PID tuning parameters might be needed for it to fly well. Currently this has to be [[https:// | * Different PID tuning parameters might be needed for it to fly well. Currently this has to be [[https:// | ||
- | * The ESC PWM output is set by default to 400Hz. Use ESCs which can handle this or compile with [[https:// | + | * The ESC PWM output is set by default to 400Hz. Use ESCs which can handle this or compile with [[https:// |
* It is wise to do a range test before flying far away. | * It is wise to do a range test before flying far away. | ||
* **Be safe**, it is experimental software. Run all testing **without** props! | * **Be safe**, it is experimental software. Run all testing **without** props! |
