User Tools
Site Tools
projects:crazyflie2:debugadapter:index
Differences
Link to this comparison view
Next revision
Previous revision
projects:crazyflie2:debugadapter:index [2015-07-15 16:31]
127.0.0.1 external edit
projects:crazyflie2:debugadapter:index [2021-06-24 16:25]
Line 1: Line 1:
 +</WRAP>
 ====== Debug adapter ====== ====== Debug adapter ======
-The debug adapter enables users to easily connect JTAG/SWD debuggers to the Crazyflie 2.platform. For debugging the STM32F4 no soldering is required, but soldering is required for debugging the nRF51.+The debug adapter enables users to easily connect JTAG/SWD debuggers to the Crazyflie 2.platform. For debugging the STM32F4 no soldering is required, but soldering is required for debugging the nRF51.
 ====== Assembly ====== ====== Assembly ======
 The Debug adapter kit contains the following: The Debug adapter kit contains the following:
-  * The nRF debug connector for soldering to the Crazyflie 2.0+  * The nRF debug connector for soldering to the Crazyflie 2.X
   * A nylon screw and nut for securely attaching the nRF51 debug connector   * A nylon screw and nut for securely attaching the nRF51 debug connector
   * The debug adapter for connecting the debugger   * The debug adapter for connecting the debugger
-  * A cable for connecting to the Crazyflie 2.0+  * A cable for connecting to the Crazyflie 2.X
-Below are two images showing how the nRF51 debug connector should be soldered to the Crazyflie 2.0.+Below are two images showing how the nRF51 debug connector should be soldered to the Crazyflie 2.X.
 {{:projects:crazyflie2:debugadapter:debug_adapter_top.jpg?500|}} {{:projects:crazyflie2:debugadapter:debug_adapter_top.jpg?500|}}
Line 27: Line 31:
     * Reset btn to <-> SDWIO: For nRF51 debugging (reset done by holding SWD IO line low)     * Reset btn to <-> SDWIO: For nRF51 debugging (reset done by holding SWD IO line low)
     * Reset btn to <-> NRST: For STM32F debugging (reset done by holding NRST low)     * Reset btn to <-> NRST: For STM32F debugging (reset done by holding NRST low)
-  * **Crazyflie 2.0 SWV**: Connect to Crazyflie 2.for nRF51 or STM32F4 debugging +  * **Crazyflie 2.0 SWV**: Connect to Crazyflie 2.for nRF51 or STM32F4 debugging
-  * **nRF51 1:1**: 1:1 match with nRF51 debug pinout on the Crazyflie 2.0 (for internal Bitcraze use :-) )+  * **nRF51 1:1**: 1:1 match with nRF51 debug pinout on the Crazyflie 2.X, pinout:
 +    SWIO
 +    - GND
 +    - VCC
 +    - SWCLK
 +====== Debug instructions ======
 +For some basic debug instructions using the VM go [[projects:virtualmachine:jtag_debug|here]]
projects/crazyflie2/debugadapter/index.txt · Last modified: 2021-06-24 16:25 by kimberly
