User Tools
Site Tools
projects:crazyflie2:expansionboards:bigquad
Differences
Link to this comparison view
Next revision
Previous revision
projects:crazyflie2:expansionboards:bigquad [2019-10-03 14:55]
tobias [Current firmware status notes (2016-03)]
projects:crazyflie2:expansionboards:bigquad [2019-10-03 14:58]
tobias [Current firmware status notes (2019-10)]
Line 103: Line 103:
 Clean and build the firmware and flash it using you preferred method. Clean and build the firmware and flash it using you preferred method.
 Now when the Crazyflie 2.0 is started and it is connected to the BigQuad deck it will start outputting PWM signals to the ESC connectors. The motors [[https://forum.bitcraze.io/viewtopic.php?f=6&t=2069#p10502|will not spin during the Crazyflie 2.0 power on self-test]] (POST). Now when the Crazyflie 2.0 is started and it is connected to the BigQuad deck it will start outputting PWM signals to the ESC connectors. The motors [[https://forum.bitcraze.io/viewtopic.php?f=6&t=2069#p10502|will not spin during the Crazyflie 2.0 power on self-test]] (POST).
-===== Current firmware status notes (2016-03)=====+===== Current firmware status notes (2019-10)=====
   * CPPM input is working but calibration and dynamic channel setup is not implemented yet. Doing the first tests with cfclient and gamepad is wise but might not be as reliable as a RC transmitter and receiver, yet.   * CPPM input is working but calibration and dynamic channel setup is not implemented yet. Doing the first tests with cfclient and gamepad is wise but might not be as reliable as a RC transmitter and receiver, yet.
   * When the BQ-Deck is detected it will automatically switch to brushless motor drivers. It will be noted in the cfclient console if it is detected or not.   * When the BQ-Deck is detected it will automatically switch to brushless motor drivers. It will be noted in the cfclient console if it is detected or not.
Line 109: Line 109:
   * Different PID tuning parameters might be needed for it to fly well. Currently this has to be [[https://github.com/bitcraze/crazyflie-firmware/blob/269730f369b4df34535708d13274abebacb71b5a/src/modules/interface/pid.h|hard coded]]. Later this will be saved in the EEPROM or in the 1-wire memory.   * Different PID tuning parameters might be needed for it to fly well. Currently this has to be [[https://github.com/bitcraze/crazyflie-firmware/blob/269730f369b4df34535708d13274abebacb71b5a/src/modules/interface/pid.h|hard coded]]. Later this will be saved in the EEPROM or in the 1-wire memory.
   * External battery voltage/current reading is implemented but no logic behind it, so don't run out of battery. You can connect the cable (MON port) and watch the log variable.   * External battery voltage/current reading is implemented but no logic behind it, so don't run out of battery. You can connect the cable (MON port) and watch the log variable.
-  * The PWM output is set to 400Hz. Use ESCs which can handle this or compile with [[https://github.com/bitcraze/crazyflie-firmware/blob/master/drivers/interface/motors.h#L89|new value]].+  * The PWM output is set to 400Hz. Use ESCs which can handle this or compile with [[https://github.com/bitcraze/crazyflie-firmware/blob/269730f369b4df34535708d13274abebacb71b5a/src/drivers/interface/motors.h#L92|new value]]. There is also the possibility to [[https://github.com/bitcraze/crazyflie-firmware/blob/269730f369b4df34535708d13274abebacb71b5a/src/drivers/interface/motors.h#L65|enable]] OneShot125 output.
   * **Be safe**, it is experimental software. Run all testing **without** props!   * **Be safe**, it is experimental software. Run all testing **without** props!
 ====== Reference setup ====== ====== Reference setup ======
projects/crazyflie2/expansionboards/bigquad.txt · Last modified: 2021-06-24 16:09 by kimberly
