projects:crazyflie2:expansionboards:bosch [2017-05-23 14:54] jan [Schematic] |
projects:crazyflie2:expansionboards:bosch [2021-06-24 16:13] kimberly |
+ | [[https:// | ||
====== Bosch Sensor Deck ====== | ====== Bosch Sensor Deck ====== | ||
- | Adds a variety of Bosch Sensortec sensors to the crazyflie2 | + | Adds a variety of Bosch Sensortec sensors to the crazyflie. |
Line 7: | Line 13: | ||
- | As there are different versions of the sensor deck, some sensors are only avaible | + | As there are different versions of the sensor deck, some sensors are only available |
- | * Intertial | + | * Inertial |
* triaxial 12-bit accelerometer (up to ± 16g) | * triaxial 12-bit accelerometer (up to ± 16g) | ||
Line 53: | Line 59: | ||
in [[https:// | in [[https:// | ||
- | Now you are ready to make the firmware and flash on your crazyflie. | + | Now you are ready to make the firmware and flash it on your crazyflie. |
+ | For evaluation purposes you might want to log sensors data which can be done with help of the [[projects: |
