projects:crazyflie2:expansionboards:bosch [2017-05-23 10:41] jan |
projects:crazyflie2:expansionboards:bosch [2021-06-24 16:13] (current) kimberly |
| + | [[https:// | ||
| ====== Bosch Sensor Deck ====== | ====== Bosch Sensor Deck ====== | ||
| - | Adds a variety of Bosch Sensortec sensors to the crazyflie2 | + | Adds a variety of Bosch Sensortec sensors to the crazyflie. |
| ===== Specification ===== | ===== Specification ===== | ||
| - | As there are different versions of the sensor deck, some sensors are only avaible | + | As there are different versions of the sensor deck, some sensors are only available |
| - | * Intertial | + | * Inertial |
| * [[https:// | * [[https:// | ||
| - | * closed loop | ||
| * triaxial 12-bit accelerometer (up to ± 16g) | * triaxial 12-bit accelerometer (up to ± 16g) | ||
| * triaxial 16 bit gyroscope (up to ± 2000°/s) | * triaxial 16 bit gyroscope (up to ± 2000°/s) | ||
| - | * open loop | ||
| * triaxial 16-bit accelerometer (up to ± 16g) | * triaxial 16-bit accelerometer (up to ± 16g) | ||
| * Accelerometer: | * Accelerometer: | ||
| - | * BMA455 (V4) upcoming sensor | + | * BMA455 (V4) triaxial 16-bit accelerometer (up to ± 16g), upcoming sensor |
| * Integrated environmental units: | * Integrated environmental units: | ||
| Line 42: | Line 46: | ||
| * Size (WxHxD): 25.2x28.75x4mm³ | * Size (WxHxD): 25.2x28.75x4mm³ | ||
| + | ===== Schematic===== | ||
| + | Bosch Sensortec expansion deck V2 {{: | ||
| ===== Setting Up ===== | ===== Setting Up ===== | ||
| If not already done create config.mk in tools/make from [[https:// | If not already done create config.mk in tools/make from [[https:// | ||
| Line 52: | Line 59: | ||
| in [[https:// | in [[https:// | ||
| - | Now you are ready to make the firmware and flash on your crazyflie. | + | Now you are ready to make the firmware and flash it on your crazyflie. |
| + | For evaluation purposes you might want to log sensors data which can be done with help of the [[projects: | ||
