projects:crazyflie2:expansionboards:breakout [2014-09-24 19:55] arnaud |
projects:crazyflie2:expansionboards:breakout [2016-03-27 01:36] fred |
- | The breakout expansion | + | The breakout expansion |
- | The board is shipped without 100mil connector. To be used on a breadboard 100mil 10 pin male should be soldered. | + | The deck is shipped without |
The 100mil connector is cabled directly to the expansion port connectors. | The 100mil connector is cabled directly to the expansion port connectors. |
