projects:crazyflie2:expansionboards:breakout
Breackout expansion board
The breakout expansion board is designed to be soldered to 100mil breadboard or prototyping board. The aim is to ease prototyping by connecting breadboard circuits to Crazyflie 2.0. It can also be used to make a bigger system using Crazyflie 2.0 as a component. The breakout board is also very useful to measure signals, for example by sticking oscilloscope probe in the 100mil connector holes.
The board is shipped without 100mil connector. To be used on a breadboard 100mil 10 pin male should be soldered.
The 100mil connector is cabled directly to the expansion port connectors.
Specification
  • Makes all 20 pins in the Crazyflie 2.0 expansion port available
  • 2.54mm header that fits a breadboard (not included)
  • Screenprint showing all signal names
  • Footprint for optional 1-wire memory (not mounted)
  • Mechanical specification:
    • Weight: 1.5 g
    • Size (WxHxD): 27x28x4mm
projects/crazyflie2/expansionboards/breakout.1411581336.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
