projects:crazyflie2:expansionboards:index [2016-11-22 14:25] tobias [Deck info] |
projects:crazyflie2:expansionboards:index [2019-02-14 14:19] kristoffer |
Line 4: | Line 4: | ||
+ | * [[projects: | ||
+ | [[projects: | ||
Line 34: | Line 40: | ||
Line 48: | Line 61: | ||
| 0xBC | 0x05 | bcBigQuad | Big quad | 3.8g | N/A | Below/Above | [[projects: | | 0xBC | 0x05 | bcBigQuad | Big quad | 3.8g | N/A | Below/Above | [[projects: | ||
- | | 0xBC | 0x08 | bcUSD | micro-SD | 1.7g | ~30mA | Below/Above | | | | + | | 0xBC | 0x08 | bcUSD | Micro-SD | 1.7g | ~30mA | Below/Above | [[projects: |
+ | | 0xBC | 0x09 | bcZRanger | Z-Ranger | 1.3g | ~15mA | Below | [[projects: | ||
+ | ^ bcZRanger, bcZRanger2 | | | X | X | | //(X)// | | | | | | | | | | VCC | | ||
+ | ^ bcFlow, bcFlow2 | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | ||
+ | ^ LED-ring | ||
+ | ^ Qi charger | ||
+ | ^ Micro-SD | ||
+ | ^ UWB LPS | yes | ||
+ | ^ Buzzer | ||
+ | ^ Z-Ranger | ||
+ | ^ Flow | yes | yes | | ||
+ | ^ Multi-ranger | ||
+ | ^ Lighthouse-4 | ||
+ | ^ LED-ring | ||
+ | ^ Micro-SD | ||
+ | ^ Buzzer | ||
+ | ^ Z-Ranger | ||
+ | ^ Flow | | | *1 | yes | ||
+ | **Notes: | ||
