| 0xBC | 0x0E | bcZRanger2 | Z-Ranger v2 | 1.3g | ~15mA | Below | N/A | N/A |
| 0xBC | 0x0F | bcFlow2 | Flow v2 | 1.6g | ~40mA | Below | N/A | N/A |
| 0xBC | 0x10 | bcLighthouse4 | Lighthouse-4 | 2.7g | ~40mA | Above | N/A | N/A |
| bcZRanger, bcZRanger2 | X | X | (X) | VCC | ||||||||||||
| bcFlow, bcFlow2 | X | X | (X) | X | X | X | X | VCC | ||||||||
| bcMultiranger | X | X | VCOM | |||||||||||||
| bcMocap | (X) | (X) | N/A | |||||||||||||
| bcLighthouse4 | X | X | X | X | N/A | |||||||||||
This table shows which deck that works on which platform.
| Crazyflie 2.X | Roadrunner | |
| LED-ring | yes | yes |
| Qi charger | yes | yes |
| Micro-SD | yes | *1 |
| UWB LPS | yes | |
| Big quad | yes | yes |
| Buzzer | yes | |
| bcESP | yes | yes |
| Z-Ranger | yes | yes |
| Flow | yes | yes |
| Multi-ranger | yes | yes |
| Mocap marker deck | yes | yes |
| Lighthouse-4 | yes | *2 |
This table shows which decks that can be used at the same time.
Note: This matrix is for unmodified decks and the standard firmware. Some decks can be modified to use other pins on the expansion port and thus work with decks that are marked as not compatible. Also decks that are normally physically blocking each other are marked as not compatible.
| LED-ring | Qi charger | Micro-SD | UWB LPS | Big quad | Buzzer | bcESP | Z-Ranger | Flow | Multi-ranger | Mocap marker deck | Lighthouse-4 | |
| LED-ring | yes | yes | yes | yes | yes | yes | yes | |||||
| Qi charger | yes | yes | yes | yes | yes | yes | yes | yes | ||||
| Micro-SD | yes | yes | *1 | yes | yes | yes | yes | *1 | yes | yes | yes | |
| UWB LPS | yes | yes | *1 | yes | yes | yes | yes | yes | yes | yes | *2 | |
| Big quad | yes | yes | yes | yes | yes | yes | *2 | |||||
| Buzzer | yes | yes | yes | yes | yes | yes | yes | yes | yes | |||
| bcESP | yes | yes | yes | yes | yes | yes | yes | yes | yes | |||
| Z-Ranger | yes | yes | yes | yes | yes | yes | yes | yes | ||||
| Flow | *1 | yes | yes | yes | yes | yes | yes | |||||
| Multi-ranger | yes | yes | yes | yes | yes | yes | yes | yes | yes | yes | yes | |
| Mocap marker deck | yes | yes | yes | yes | yes | yes | yes | yes | yes | yes | yes | |
| Lighthouse-4 | yes | yes | yes | *2 | *2 | yes | yes | yes | yes | yes | yes |
Notes:
