projects:crazyflie2:expansionboards:index [2017-01-25 13:10] tobias [Deck info] |
projects:crazyflie2:expansionboards:index [2019-01-30 10:33] macke |
Line 4: | Line 4: | ||
+ | * [[projects: | ||
+ | [[projects: | ||
Line 34: | Line 40: | ||
Line 49: | Line 62: | ||
+ | | 0xBC | 0x09 | bcZRanger | Z-Ranger | 1.3g | ~15mA | Below | [[projects: | ||
Line 63: | Line 86: | ||
| bcBuzzer | | | | | | | | | PWM | PWM | | | | | | N/A | | | bcBuzzer | | | | | | | | | PWM | PWM | | | | | | N/A | | ||
| bcESP | | | | | | | | //(X)// | X | X | | | | | | N/A | | | bcESP | | | | | | | | //(X)// | X | X | | | | | | N/A | | ||
+ | | bcZRanger | | | X | X | | //(X)// | | | | | | | | | | VCC | | ||
+ | | bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | ||
+ | | bcLighthouse4 | X | X | X | X | | | | | | | | | | | | N/A | | ||
