projects:crazyflie2:expansionboards:index
Expansion decks
Mechanical architecture
Orientation
One expansion board on top
One expansion board on top, one on bottom
Two expansion board on top
Expansion port pinout
  • The Crazyflie 2.0 is a 3.0V system, meaning a high output will be 3.0V but still compatible with a 3.3V system.
  • VCC can supply max 100mA
  • VCOM can supply max 1.0A
  • All IO pins are 5V tolerant except PA5 and the NRF51 pins
  • The NRF51 pins can be multiplexed with any of the available NRF51 peripheral.
  • The STM32F405RG pins can be multiplexed with more functions.
Expansion board detection
Deck info
VID PID ID Name Weight Consumption Mount location Details page Schematic
0xBC 0x01 bcLedRing LED-ring 3.3g 0 - 700mA Below link link
0xBC 0x02 bcQi Qi charger 5g N/A Below link link
0xBC 0x04 bcBuzzer Buzzer 1.8g 10mA Below/Above link link
0xBC 0x05 bcBigQuad Big quad 3.8g N/A Below/Above link link
0xBC 0x06 bcDWM UWB LPS 3.3g 160mA Below/Above link link
0xBC 0x08 bcUSD Micro-SD 1.7g ~30mA Below/Above link link
0xBC 0x09 bcZRanger Z-Ranger 1.3g ~15mA Below link link
0xBC 0x0A bcFlow Flow 1.6g ~40mA Below link link
0xBC 0x0B bcOA Obstacle Avoidance N/A ~0.3mA Above N/A N/A
0xBC 0x0C bcMultiranger Multi-ranger N/A ~90mA (depending on mode) Above N/A N/A
0xBC 0x0D bcMocap Mocap marker deck N/A 0mA Above N/A N/A
0xBC 0x0E bcZRanger2 Z-Ranger v2 1.3g ~15mA Below N/A N/A
0xBC 0x0F bcFlow2 Flow v2 1.6g ~40mA Below N/A N/A
0xBC 0x10 bcLighthouse4 Lighthouse-4 2.7g ~40mA Above N/A N/A
Deck pin allocation
UART1 I2C STM32 IO UART2 SPI nRF51 IO
Name RX1 TX1 SDA SCL IO1 IO2 IO3 IO4 TX2 RX2 CLK MOSI MISO NIO1 NIO2 PWR
bcLedRing PWM PWM VCOM
bcQi GHG N/A
bcGPS X X (PP)S (RST) (X) (X) (VBAT) VCOM
bcUSD (CS) (CS) (CS) CS X X X VCC
bcDWM IRQ RST CS (IRQ) (RST) X X X VCOM
bcBigQuad (X) (X) (X) (X) X X (X) X X (X) (X) (X) N/A
bcBuzzer PWM PWM N/A
bcESP (X) X X N/A
bcZRanger X X (X) VCC
bcFlow X X (X) X X X X VCC
bcOA X X VCC
bcMultiranger X X VCOM
bcMocap (X) (X) N/A
bcLighthouse4 X X X X N/A
projects/crazyflie2/expansionboards/index.1548840831.txt.gz · Last modified: 2019-01-30 10:33 by macke
