projects:crazyflie2:expansionboards:index [2017-03-14 13:51] tobias [Deck info] |
projects:crazyflie2:expansionboards:index [2019-02-14 14:19] kristoffer |
Line 4: | Line 4: | ||
+ | * [[projects: | ||
Line 9: | Line 10: | ||
+ | [[projects: | ||
Line 36: | Line 40: | ||
Line 51: | Line 62: | ||
+ | ^ bcFlow, bcFlow2 | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | ||
+ | ^ LED-ring | ||
+ | ^ Qi charger | ||
+ | ^ Micro-SD | ||
+ | ^ UWB LPS | yes | ||
+ | ^ Buzzer | ||
+ | ^ Z-Ranger | ||
+ | ^ Flow | yes | yes | | ||
+ | ^ Multi-ranger | ||
+ | ^ Lighthouse-4 | ||
+ | ^ LED-ring | ||
+ | ^ Micro-SD | ||
+ | ^ Buzzer | ||
+ | ^ Z-Ranger | ||
+ | ^ Flow | | | *1 | yes | ||
+ | **Notes: | ||
