projects:crazyflie2:expansionboards:index [2017-05-11 16:26] arnaud [Deck info] |
projects:crazyflie2:expansionboards:index [2018-12-18 11:36] tobias old revision restored (2018-10-30 13:37) |
Line 9: | Line 9: | ||
+ | [[projects: | ||
Line 36: | Line 37: | ||
Line 51: | Line 59: | ||
- | | 0xBC | 0x0A | bcFlow | Flow | 1.6g | ~40mA | Below | TBD | TBD | | + | | 0xBC | 0x0A | bcFlow | Flow | 1.6g | ~40mA | Below | [[projects: |
Line 68: | Line 82: | ||
| bcESP | | | | | | | | //(X)// | X | X | | | | | | N/A | | | bcESP | | | | | | | | //(X)// | X | X | | | | | | N/A | | ||
| bcZRanger | | | X | X | | //(X)// | | | | | | | | | | VCC | | | bcZRanger | | | X | X | | //(X)// | | | | | | | | | | VCC | | ||
+ | | bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | ||
