0xBC | 0x09 | bcZRanger | Z-Ranger | 1.3g | ~30mA | Below | link | link |
0xBC | 0x0A | bcFlow | Flow | 1.6g | ~40mA | Below | TBD | TBD |
bcZRanger | X | X | (X) | VCC |
