projects:crazyflie2:expansionboards:index [2017-10-05 13:41] arnaud [Deck info] |
projects:crazyflie2:expansionboards:index [2019-02-14 14:19] kristoffer |
Line 4: | Line 4: | ||
+ | * [[projects: | ||
Line 10: | Line 11: | ||
+ | [[projects: | ||
Line 36: | Line 40: | ||
Line 51: | Line 62: | ||
- | | 0xBC | 0x0B | bcOA | Obstacle Avoidance | N/A | N/A | Above | N/A | N/A | | + | | 0xBC | 0x0B | bcOA | Obstacle Avoidance | N/A | ~0.3mA | Above | N/A | N/A | |
+ | ^ LED-ring | ||
+ | ^ Qi charger | ||
+ | ^ Micro-SD | ||
+ | ^ UWB LPS | yes | ||
+ | ^ Buzzer | ||
+ | ^ Z-Ranger | ||
+ | ^ Flow | yes | yes | | ||
+ | ^ Multi-ranger | ||
+ | ^ Lighthouse-4 | ||
+ | ^ LED-ring | ||
+ | ^ Micro-SD | ||
+ | ^ Buzzer | ||
+ | ^ Z-Ranger | ||
+ | ^ Flow | | | *1 | yes | ||
+ | **Notes: | ||
