projects:crazyflie2:expansionboards:index [2019-01-29 17:36] macke |
projects:crazyflie2:expansionboards:index [2019-02-14 14:19] kristoffer |
Line 4: | Line 4: | ||
+ | * [[projects: | ||
Line 77: | Line 78: | ||
- | | bcOA | | | X | X | | | | | | | | | | | | VCC | | + | ^ bcOA | | | X | X | | | | | | | | | | | | VCC | |
- | | bcMultiranger | | | X | X | | | | | | | | | | | | VCOM | | + | ^ bcMultiranger | | | X | X | | | | | | | | | | | | VCOM | |
- | | bcMocap | | | | | | //(X)// | //(X)// | | | | | | | | | N/A | | + | ^ bcMocap | | | | | | //(X)// | //(X)// | | | | | | | | | N/A | |
- | | bcLighthouse4 | X | X | X | X | | | | | | | | | | | | N/A | | + | ^ bcLighthouse4 | X | X | X | X | | | | | | | | | | | | N/A | |
+ | ^ LED-ring | ||
+ | ^ Qi charger | ||
+ | ^ Micro-SD | ||
+ | ^ UWB LPS | yes | ||
+ | ^ Buzzer | ||
+ | ^ Z-Ranger | ||
+ | ^ Flow | yes | yes | | ||
+ | ^ Multi-ranger | ||
+ | ^ Lighthouse-4 | ||
+ | ^ LED-ring | ||
+ | ^ Micro-SD | ||
+ | ^ Buzzer | ||
+ | ^ Z-Ranger | ||
+ | ^ Flow | | | *1 | yes | ||
+ | **Notes:** | ||
