User Tools
Site Tools
projects:crazyflie2:expansionboards:index
Differences
Link to this comparison view
Next revision
Previous revision
projects:crazyflie2:expansionboards:index [2018-03-14 09:11]
kristoffer [Deck pin allocation]
projects:crazyflie2:expansionboards:index [2018-12-18 11:34]
tobias old revision restored (2018-06-21 10:07)
Line 36: Line 36:
 {{:projects:crazyflie2:expansionboards:connector_multiplexing2.png?direct&900|}} {{:projects:crazyflie2:expansionboards:connector_multiplexing2.png?direct&900|}}
-The NRF51 pins can be multiplexed with any of the available NRF51 peripheral. The STM32F405RG pins can be multiplexed with more functionssee datasheets for more information.+  * The Crazyflie 2.0 is a 3.0V system, meaning a high output will be 3.0V but still compatible with a 3.3V system.
 +  * VCC can supply max 100mA
 +  * VCOM can supply max 1.0A
 +  * All IO pins are 5V tolerant except PA5 and the NRF51 pins
 +  * The NRF51 pins can be multiplexed with any of the available NRF51 peripheral.
 +  * The STM32F405RG pins can be multiplexed with more functions
 +For full specification see the datasheets of the NRF51 and the STM32F405
 ===== Expansion board detection ===== ===== Expansion board detection =====
Line 54: Line 61:
 | 0xBC | 0x0A | bcFlow | Flow | 1.6g | ~40mA | Below | [[projects:crazyflie2:expansionboards:flow|link]] | {{ :projects:crazyflie2:expansionboards:flow-deck_reve.pdf | link }} | | 0xBC | 0x0A | bcFlow | Flow | 1.6g | ~40mA | Below | [[projects:crazyflie2:expansionboards:flow|link]] | {{ :projects:crazyflie2:expansionboards:flow-deck_reve.pdf | link }} |
 | 0xBC | 0x0B | bcOA | Obstacle Avoidance | N/A | ~0.3mA | Above | N/A | N/A | | 0xBC | 0x0B | bcOA | Obstacle Avoidance | N/A | ~0.3mA | Above | N/A | N/A |
 +| 0xBC | 0x0C | bcMultiranger | Multi-ranger | N/A | ~90mA (depending on mode) | Above | N/A | N/A |
 +| 0xBC | 0x0D | bcMocap | Mocap marker deck | N/A | 0mA | Above | N/A | N/A |
 +| 0xBC | 0x0E | bcZRanger2 | Z-Ranger v2 | 1.3g | ~15mA | Below | N/A | N/A |
 +| 0xBC | 0x0F | bcFlow2 | Flow v2 | 1.6g | ~40mA | Below | N/A | N/A |
 ===== Deck pin allocation ===== ===== Deck pin allocation =====
 Below is a table showing which pins each deck uses. The table also contains information about boards that are not released yet, these are subject to change.  Below is a table showing which pins each deck uses. The table also contains information about boards that are not released yet, these are subject to change.
Line 72: Line 83:
 | bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC |
 | bcOA | | | X | X | | | | | | | | | | | | VCC | | bcOA | | | X | X | | | | | | | | | | | | VCC |
 +| bcMultiranger | | | X | X | | | | | | | | | | | | VCOM |
 +| bcMocap | | | | | | //(X)// | //(X)// | | | | | | | | | N/A |
projects/crazyflie2/expansionboards/index.txt · Last modified: 2020-05-12 13:58 by kimberly
