projects:crazyflie2:expansionboards:index [2018-12-18 11:34] tobias old revision restored (2018-06-21 10:07) |
projects:crazyflie2:expansionboards:index [2018-12-18 16:04] arnaud |
Line 10: | Line 10: | ||
- | * [[projects: | + | |
+ | [[projects: | ||
Line 65: | Line 66: | ||
| 0xBC | 0x0E | bcZRanger2 | Z-Ranger v2 | 1.3g | ~15mA | Below | N/A | N/A | | | 0xBC | 0x0E | bcZRanger2 | Z-Ranger v2 | 1.3g | ~15mA | Below | N/A | N/A | | ||
| 0xBC | 0x0F | bcFlow2 | Flow v2 | 1.6g | ~40mA | Below | N/A | N/A | | | 0xBC | 0x0F | bcFlow2 | Flow v2 | 1.6g | ~40mA | Below | N/A | N/A | | ||
Below is a table showing which pins each deck uses. The table also contains information about boards that are not released yet, these are subject to change. | Below is a table showing which pins each deck uses. The table also contains information about boards that are not released yet, these are subject to change. | ||
Line 85: | Line 88: | ||
| bcMultiranger | | | X | X | | | | | | | | | | | | VCOM | | | bcMultiranger | | | X | X | | | | | | | | | | | | VCOM | | ||
| bcMocap | | | | | | //(X)// | //(X)// | | | | | | | | | N/A | | | bcMocap | | | | | | //(X)// | //(X)// | | | | | | | | | N/A | | ||
+ | | bcLighthouse4 | X | X | X | X | | | | | | | | | | | | N/A | | ||
