| 0xBC | 0x0E | bcZRanger2 | Z-Ranger v2 | 1.3g | ~15mA | Below | N/A | N/A |
| 0xBC | 0x0F | bcFlow2 | Flow v2 | 1.6g | ~40mA | Below | N/A | N/A |
| 0xBC | 0x10 | bcLighthouse4 | Lighthouse-4 | 2.7g | ~40mA | Above | N/A | N/A |
| bcMultiranger | X | X | VCOM | |||||||||||||
| bcMocap | (X) | (X) | N/A | |||||||||||||
| bcLighthouse4 | X | X | X | X | N/A | |||||||||||
