projects:crazyflie2:expansionboards:index [2018-12-18 11:36] tobias old revision restored (2018-10-30 13:37) |
projects:crazyflie2:expansionboards:index [2019-01-30 10:33] macke |
Line 4: | Line 4: | ||
+ | * [[projects: | ||
Line 10: | Line 11: | ||
[[projects: | [[projects: | ||
Line 66: | Line 69: | ||
| 0xBC | 0x0E | bcZRanger2 | Z-Ranger v2 | 1.3g | ~15mA | Below | N/A | N/A | | | 0xBC | 0x0E | bcZRanger2 | Z-Ranger v2 | 1.3g | ~15mA | Below | N/A | N/A | | ||
| 0xBC | 0x0F | bcFlow2 | Flow v2 | 1.6g | ~40mA | Below | N/A | N/A | | | 0xBC | 0x0F | bcFlow2 | Flow v2 | 1.6g | ~40mA | Below | N/A | N/A | | ||
Below is a table showing which pins each deck uses. The table also contains information about boards that are not released yet, these are subject to change. | Below is a table showing which pins each deck uses. The table also contains information about boards that are not released yet, these are subject to change. | ||
Line 86: | Line 91: | ||
| bcMultiranger | | | X | X | | | | | | | | | | | | VCOM | | | bcMultiranger | | | X | X | | | | | | | | | | | | VCOM | | ||
| bcMocap | | | | | | //(X)// | //(X)// | | | | | | | | | N/A | | | bcMocap | | | | | | //(X)// | //(X)// | | | | | | | | | N/A | | ||
+ | | bcLighthouse4 | X | X | X | X | | | | | | | | | | | | N/A | | ||
