projects:crazyflie2:expansionboards:index [2018-12-18 16:04] arnaud |
projects:crazyflie2:expansionboards:index [2020-05-12 13:58] (current) kimberly |
| ====== Expansion decks ====== | ====== Expansion decks ====== | ||
| Line 4: | Line 9: | ||
| + | * [[projects: | ||
| Line 10: | Line 16: | ||
| [[projects: | [[projects: | ||
| Line 75: | Line 84: | ||
| ^ Name ^ RX1 ^ TX1 ^ SDA ^ SCL ^ IO1 ^ IO2 ^ IO3 ^ IO4 ^ TX2 ^ RX2 ^ CLK ^ MOSI ^ MISO ^ NIO1 ^ NIO2 ^ PWR ^ | ^ Name ^ RX1 ^ TX1 ^ SDA ^ SCL ^ IO1 ^ IO2 ^ IO3 ^ IO4 ^ TX2 ^ RX2 ^ CLK ^ MOSI ^ MISO ^ NIO1 ^ NIO2 ^ PWR ^ | ||
| - | | bcLedRing | | | | | | PWM | PWM | | | | | | | | | VCOM | | + | ^ bcLedRing | | | | | | PWM | PWM | | | | | | | | | VCOM | |
| - | | bcQi | | | | | | | | | | | | | | GHG | | N/A | | + | ^ bcQi | | | | | | | | | | | | | | GHG | | N/A | |
| - | | bcGPS | X | X | | | //(PP)S// | | //(RST)// | | //(X)// | //(X)// | | | | | //(VBAT)// | VCOM | | + | ^ bcGPS | X | X | | | //(PP)S// | | //(RST)// | | //(X)// | //(X)// | | | | | //(VBAT)// | VCOM | |
| - | | bcUSD | | | | | //(CS)// | //(CS)// | //(CS)// | CS | | | X | X | X | | | VCC | | + | ^ bcUSD | | | | | //(CS)// | //(CS)// | //(CS)// | CS | | | X | X | X | | | VCC | |
| - | | bcDWM | IRQ | RST | | | CS | //(IRQ)// | //(RST)// | | | | X | X | X | | | VCOM | | + | ^ bcDWM | IRQ | RST | | | CS | //(IRQ)// | //(RST)// | | | | X | X | X | | | VCOM | |
| - | | bcBigQuad | + | ^ bcBigQuad |
| - | | bcBuzzer | | | | | | | | | PWM | PWM | | | | | | N/A | | + | ^ bcBuzzer | | | | | | | | | PWM | PWM | | | | | | N/A | |
| - | | bcESP | | | | | | | | //(X)// | X | X | | | | | | N/A | | + | ^ bcESP | | | | | | | | //(X)// | X | X | | | | | | N/A | |
| - | | bcZRanger | | | X | X | | //(X)// | | | | | | | | | | VCC | | + | ^ bcZRanger, bcZRanger2 |
| - | | bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | + | ^ bcFlow, bcFlow2 |
| - | | bcOA | | | X | X | | | | | | | | | | | | VCC | | + | ^ bcOA | | | X | X | | | | | | | | | | | | VCC | |
| - | | bcMultiranger | | | X | X | | | | | | | | | | | | VCOM | | + | ^ bcMultiranger | | | X | X | | | | | | | | | | | | VCOM | |
| - | | bcMocap | | | | | | //(X)// | //(X)// | | | | | | | | | N/A | | + | ^ bcMocap | | | | | | //(X)// | //(X)// | | | | | | | | | N/A | |
| - | | bcLighthouse4 | X | X | X | X | | | | | | | | | | | | N/A | | + | ^ bcLighthouse4 | X | X | X | X | | | | | | | | | | | | N/A | |
| + | ===== Compatibility matrixes ===== | ||
| + | ==== Platform - deck ==== | ||
| + | This table shows which deck that works on which platform. | ||
| + | | ^ Crazyflie 2.X ^ Roadrunner ^ | ||
| + | ^ LED-ring | ||
| + | ^ Qi charger | ||
| + | ^ Micro-SD | ||
| + | ^ UWB LPS | yes | ||
| + | ^ Big quad | yes | yes | | ||
| + | ^ Buzzer | ||
| + | ^ bcESP | yes | yes | | ||
| + | ^ Z-Ranger, Z-Ranger V2 | yes | yes | | ||
| + | ^ Flow, Flow V2 | yes | yes | | ||
| + | ^ Multi-ranger | ||
| + | ^ Mocap marker deck | yes | yes | | ||
| + | ^ Lighthouse-4 | ||
| + | ==== Deck - deck ==== | ||
| + | This table shows which decks that can be used at the same time. | ||
| + | **Note**: This matrix is for unmodified decks and the standard firmware. Some decks | ||
| + | can be modified to use other pins on the expansion port and thus work with | ||
| + | decks that are marked as not compatible. Also decks that are normally physically | ||
| + | blocking each other are marked as not compatible. | ||
| + | | ^ LED-ring ^ Qi charger ^ Micro-SD ^ UWB LPS ^ Big quad ^ Buzzer ^ bcESP ^ Z-Ranger ^ Flow ^ Multi-ranger ^ Mocap marker deck ^ Lighthouse-4 ^ | ||
| + | ^ LED-ring | ||
| + | ^ Micro-SD | ||
| + | ^ UWB LPS | yes | yes | *1 | ||
| + | ^ Big quad | | yes | yes | yes | ||
| + | ^ Buzzer | ||
| + | ^ bcESP | yes | yes | yes | yes | ||
| + | ^ Z-Ranger, Z-Ranger V2 | | | yes | yes | yes | yes | yes | ||
| + | ^ Flow, Flow V2 | ||
| + | ^ Mocap marker deck | yes | yes | yes | yes | yes | yes | yes | yes | yes | yes | | yes | | ||
| + | **Notes:** | ||
| + | - SPI sharing issue, see https:// | ||
| + | - Will be supported in the future, SW update | ||
