projects:crazyflie2:expansionboards:index [2018-12-18 16:04] arnaud |
projects:crazyflie2:expansionboards:index [2020-05-12 13:58] (current) kimberly |
Line 4: | Line 9: | ||
+ | * [[projects: | ||
Line 10: | Line 16: | ||
[[projects: | [[projects: | ||
Line 75: | Line 84: | ||
- | | bcOA | | | X | X | | | | | | | | | | | | VCC | | + | ^ bcOA | | | X | X | | | | | | | | | | | | VCC | |
- | | bcMultiranger | | | X | X | | | | | | | | | | | | VCOM | | + | ^ bcMultiranger | | | X | X | | | | | | | | | | | | VCOM | |
- | | bcMocap | | | | | | //(X)// | //(X)// | | | | | | | | | N/A | | + | ^ bcMocap | | | | | | //(X)// | //(X)// | | | | | | | | | N/A | |
- | | bcLighthouse4 | X | X | X | X | | | | | | | | | | | | N/A | | + | ^ bcLighthouse4 | X | X | X | X | | | | | | | | | | | | N/A | |
+ | ^ LED-ring | ||
+ | ^ Qi charger | ||
+ | ^ Micro-SD | ||
+ | ^ UWB LPS | yes | ||
+ | ^ Buzzer | ||
+ | ^ Multi-ranger | ||
+ | ^ Lighthouse-4 | ||
+ | ^ LED-ring | ||
+ | ^ Micro-SD | ||
+ | ^ Buzzer | ||
+ | ^ Flow, Flow V2 | ||
+ | **Notes:** | ||
