User Tools
Site Tools
projects:crazyflie2:expansionboards:index
Differences
Link to this comparison view
Next revision
Previous revision
projects:crazyflie2:expansionboards:index [2019-01-30 10:33]
macke
projects:crazyflie2:expansionboards:index [2020-05-12 13:58] (current)
Line 1: Line 1:
 +This page has deprecated and moved to the new documentation framework of the main Bitcraze website. Please go to [[https://www.bitcraze.io/documentation/system/]]
 +</WRAP>
 ====== Expansion decks ====== ====== Expansion decks ======
Line 13: Line 18:
   * [[projects:crazyflie2:expansionboards:lighthouse|Lighthouse positioning deck]]: Expansion deck that supports the SteamVR Lighthouse positioning   * [[projects:crazyflie2:expansionboards:lighthouse|Lighthouse positioning deck]]: Expansion deck that supports the SteamVR Lighthouse positioning
   * [[projects:crazyflie2:expansionboards:mocapmarker|Motion capture marker deck]]: Expansion deck where motion capture markers can easily be mounted   * [[projects:crazyflie2:expansionboards:mocapmarker|Motion capture marker deck]]: Expansion deck where motion capture markers can easily be mounted
 +  * [[projects:crazyflie2:aideck|AI-deck]]: Expansion deck with a camera, WiFi an AI on the edge MCU.
 [[projects:crazyflie2:expansionboards:template|Expansion board template]]: The Crazyflie 2.0 expansion port template explained [[projects:crazyflie2:expansionboards:template|Expansion board template]]: The Crazyflie 2.0 expansion port template explained
Line 78: Line 84:
 |    UART1  ^^  I2C  ^^  STM32 IO  ^^^^  UART2  ^^  SPI  ^^^  nRF51 IO  ^^  |    UART1  ^^  I2C  ^^  STM32 IO  ^^^^  UART2  ^^  SPI  ^^^  nRF51 IO  ^^
 ^  Name  ^  RX1  ^  TX1  ^  SDA  ^  SCL  ^  IO1  ^  IO2  ^ IO3  ^  IO4  ^  TX2  ^  RX2  ^  CLK  ^  MOSI  ^  MISO  ^  NIO1  ^  NIO2  ^  PWR  ^ ^  Name  ^  RX1  ^  TX1  ^  SDA  ^  SCL  ^  IO1  ^  IO2  ^ IO3  ^  IO4  ^  TX2  ^  RX2  ^  CLK  ^  MOSI  ^  MISO  ^  NIO1  ^  NIO2  ^  PWR  ^
-bcLedRing | | | | | | PWM | PWM | | | | | | | | | VCOM | +bcLedRing | | | | | | PWM | PWM | | | | | | | | | VCOM |
-bcQi | | | | | | | | | | | | | | GHG | | N/A | +bcQi | | | | | | | | | | | | | | GHG | | N/A |
-bcGPS | X | X | | | //(PP)S// | | //(RST)// | | //(X)// | //(X)// | | | | | //(VBAT)// | VCOM | +bcGPS | X | X | | | //(PP)S// | | //(RST)// | | //(X)// | //(X)// | | | | | //(VBAT)// | VCOM |
-bcUSD | | | | | //(CS)// | //(CS)// | //(CS)// | CS | | | X | X | X | | | VCC | +bcUSD | | | | | //(CS)// | //(CS)// | //(CS)// | CS | | | X | X | X | | | VCC |
-bcDWM | IRQ | RST | | | CS | //(IRQ)// | //(RST)// | | | | X | X | X | | | VCOM | +bcDWM | IRQ | RST | | | CS | //(IRQ)// | //(RST)// | | | | X | X | X | | | VCOM |
-bcBigQuad  | //(X)// | //(X)// | //(X)// | //(X)// |  | **X** | **X** | //(X)// | **X** | **X** | //(X)// | //(X)// | //(X)// | | | N/A | +bcBigQuad  | //(X)// | //(X)// | //(X)// | //(X)// |  | **X** | **X** | //(X)// | **X** | **X** | //(X)// | //(X)// | //(X)// | | | N/A |
-bcBuzzer | | | | | | | | | PWM | PWM | | | | | | N/A | +bcBuzzer | | | | | | | | | PWM | PWM | | | | | | N/A |
-bcESP | | | | | | | | //(X)// | X | X | | | | | | N/A | +bcESP | | | | | | | | //(X)// | X | X | | | | | | N/A |
-bcZRanger | | | X | X | | //(X)// | | | | | | | | | | VCC | +bcZRanger, bcZRanger2 | | | X | X | | //(X)// | | | | | | | | | | VCC |
-bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | +bcFlow, bcFlow2 | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC |
-bcOA | | | X | X | | | | | | | | | | | | VCC | +bcOA | | | X | X | | | | | | | | | | | | VCC |
-bcMultiranger | | | X | X | | | | | | | | | | | | VCOM | +bcMultiranger | | | X | X | | | | | | | | | | | | VCOM |
-bcMocap | | | | | | //(X)// | //(X)// | | | | | | | | | N/A | +bcMocap | | | | | | //(X)// | //(X)// | | | | | | | | | N/A |
-bcLighthouse4 | X | X | X | X | | | | | | | | | | | | N/A |+bcLighthouse4 | X | X | X | X | | | | | | | | | | | | N/A
 +===== Compatibility matrixes =====
 +==== Platform - deck ====
 +This table shows which deck that works on which platform.
 +|                       ^ Crazyflie 2.X ^ Roadrunner ^
 +^ LED-ring              | yes           | yes        |
 +^ Qi charger            | yes           | yes        |
 +^ Micro-SD              | yes           | *1         |
 +^ UWB LPS               | yes                      |
 +^ Big quad              | yes           | yes        |
 +^ Buzzer                | yes                      |
 +^ bcESP                 | yes           | yes        |
 +^ Z-Ranger, Z-Ranger V2 | yes           | yes        |
 +^ Flow, Flow V2         | yes           | yes        |
 +^ Multi-ranger          | yes           | yes        |
 +^ Mocap marker deck     | yes           | yes        |
 +^ Lighthouse-4          | yes           | *2         |
 +==== Deck - deck ====
 +This table shows which decks that can be used at the same time.
 +**Note**: This matrix is for unmodified decks and the standard firmware. Some decks
 +can be modified to use other pins on the expansion port and thus work with
 +decks that are marked as not compatible. Also decks that are normally physically
 +blocking each other are marked as not compatible.
 +|                       ^ LED-ring ^ Qi charger ^ Micro-SD ^ UWB LPS ^ Big quad ^ Buzzer ^ bcESP ^ Z-Ranger ^ Flow ^ Multi-ranger ^ Mocap marker deck ^ Lighthouse-4 ^
 +^ LED-ring              |          |            | yes      | yes              | yes    | yes            |      | yes          | yes               | yes          |
 +^ Qi charger            |          |            | yes      | yes     | yes      | yes    | yes            |      | yes          | yes               | yes          |
 +^ Micro-SD              | yes      | yes        |          | *1      | yes      | yes    | yes   | yes      | *1   | yes          | yes               | yes          |
 +^ UWB LPS               | yes      | yes        | *1               | yes      | yes    | yes   | yes      | yes  | yes          | yes               | *2           |
 +^ Big quad              |          | yes        | yes      | yes              |        |       | yes      |      | yes          | yes               | *2           |
 +^ Buzzer                | yes      | yes        | yes      | yes              |        |       | yes      | yes  | yes          | yes               | yes          |
 +^ bcESP                 | yes      | yes        | yes      | yes              |        |       | yes      | yes  | yes          | yes               | yes          |
 +^ Z-Ranger, Z-Ranger V2 |          |            | yes      | yes     | yes      | yes    | yes            |      | yes          | yes               | yes          |
 +^ Flow, Flow V2                  |            | *1       | yes              | yes    | yes            |      | yes          | yes               | yes          |
 +^ Multi-ranger          | yes      | yes        | yes      | yes     | yes      | yes    | yes   | yes      | yes  |              | yes               | yes          |
 +^ Mocap marker deck     | yes      | yes        | yes      | yes     | yes      | yes    | yes   | yes      | yes  | yes          |                   | yes          |
 +^ Lighthouse-4          | yes      | yes        | yes      | *2      | *2       | yes    | yes   | yes      | yes  | yes          | yes                            |
 +**Notes:**
 +  - SPI sharing issue, see https://github.com/bitcraze/crazyflie-firmware/issues/270
 +  - Will be supported in the future, SW update
projects/crazyflie2/expansionboards/index.1548840831.txt.gz · Last modified: 2019-01-30 10:33 by macke
