projects:crazyflie2:expansionboards:microsd [2018-05-30 18:59] whoenig [Data Logging] |
projects:crazyflie2:expansionboards:microsd [2021-05-21 09:39] kimberly |
+ | [[https:// | ||
====== micro-SD expansion deck ====== | ====== micro-SD expansion deck ====== | ||
Line 46: | Line 52: | ||
where fileName is a file from the µSD-Card. For convenience there is also an [[https:// | where fileName is a file from the µSD-Card. For convenience there is also an [[https:// | ||
+ | ===== Current limitations [SOLVED] ====== | ||
+ | The SD-Card is using the SPI bus on the deck port to communicate. This has turned out to have some implications for the other decks that use the SPI bus. The effected decks are the Loco-deck and the Flow v1,v2 deck. An [[https:// | ||
+ | - First thing the SD-card deck needs to be patched, CS-> | ||
+ | - Compile the firmware with " | ||
+ | - If you want to use the Loco-deck at the same time, the alternative pins for this must be used. This means cutting GS1 and GS2 underneeth the loco-deck and soldering the bridged GS3 and GS4. Then add " | ||
