projects:crazyflie2:expansionboards:microsd [2020-03-13 16:13] tobias |
projects:crazyflie2:expansionboards:microsd [2021-06-24 16:13] (current) kimberly |
+ | [[https:// | ||
====== micro-SD expansion deck ====== | ====== micro-SD expansion deck ====== | ||
Line 47: | Line 55: | ||
where fileName is a file from the µSD-Card. For convenience there is also an [[https:// | where fileName is a file from the µSD-Card. For convenience there is also an [[https:// | ||
- | ===== Current limitations ====== | + | ===== Current limitations |
- | The SD-Card is using the SPI bus on the deck port to communicate. This has turned out to have some implications for the other decks that use the SPI bus. The effected decks are the Loco-deck and the Flow v1,v2 deck. An [[https:// | + | The SD-Card is using the SPI bus on the deck port to communicate. This has turned out to have some implications for the other decks that use the SPI bus. The effected decks are the Loco-deck and the Flow v1,v2 deck. An [[https:// |
- First thing the SD-card deck needs to be patched, CS-> | - First thing the SD-card deck needs to be patched, CS-> |
