projects:crazyflie2:expansionboards:proto [2016-01-26 00:45] fred typo |
projects:crazyflie2:expansionboards:proto [2016-03-30 14:40] bjorn |
- | The prototype expansion board allows | + | The prototyping deck allows electronic |
- | Both throw holes some smd components can be soldered to the board. The shape of the pads makes it possible to solder SMD capacitor and resistor which saves space and weight. | + | Both through |
The two pad rows that are closest to the expansion connector are connected to the connectors. | The two pad rows that are closest to the expansion connector are connected to the connectors. | ||
Line 19: | Line 19: | ||
===== Detection memory ===== | ===== Detection memory ===== | ||
- | If you want your prototype | + | If you want your prototype |
