projects:crazyflie2:expansionboards:proto [2016-03-30 14:24] bjorn |
projects:crazyflie2:expansionboards:proto [2016-03-30 14:39] bjorn |
- | ====== Prototyping | + | ====== Prototyping deck ====== |
- | The prototype expansion | + | The prototyping |
Both through holes and SMD components can be soldered to the deck. The shape of the pads makes it possible to solder SMD capacitor and resistor which saves space and weight. | Both through holes and SMD components can be soldered to the deck. The shape of the pads makes it possible to solder SMD capacitor and resistor which saves space and weight. | ||
Line 19: | Line 19: | ||
===== Detection memory ===== | ===== Detection memory ===== | ||
- | If you want your prototype deck to be detected automatically by the Crazyflie, for example to activate your driver code when the deck is connected, you can solder a one-wire memory DS28E05 in the pads near P1 pin 10. For more information about the automatic expansion deck detection see [[projects: | + | If you want your prototype deck to be detected automatically by the Crazyflie, for example to activate your driver code when the deck is connected, you can solder a one-wire memory DS28E05 in the pads near P1 pin 10. |
