projects:crazyflie2:expansionboards:qi [2014-09-24 19:50] arnaud |
projects:crazyflie2:expansionboards:qi [2016-02-04 16:15] kristoffer |
- | ====== Qi Wireless charging expansion | + | ====== Qi Wireless charging expansion |
- | The Qi wireless charging expansion | + | The Qi wireless charging expansion |
- | The board is designed to be installed as the last board on the bottom of the Crazyflie 2.0. It does not have pass-throw holes for the expansion port connector. | + | The deck is designed to be installed as the last deck on the bottom of the Crazyflie 2.0. It does not have pass-through |
- | This expansion | + | This expansion |
- | The board works by injecting 5V in the Crazyflie 2.0 VUSB line. In consequence it is recommended | + | The deck works by injecting 5V into the Crazyflie 2.0 VUSB line. As a consequence, it is not recommended |
Line 13: | Line 13: | ||
* Can supply up to 1A at 5V | * Can supply up to 1A at 5V | ||
* Supports the Qi wireless charging standard (WPC V1.1) | * Supports the Qi wireless charging standard (WPC V1.1) | ||
- | * 1-wire memory for automatic expansion | + | * 1-wire memory for automatic expansion |
* Designed for mounting under the Crazyflie 2.0 | * Designed for mounting under the Crazyflie 2.0 | ||
* Mechanical specification: | * Mechanical specification: | ||
Line 19: | Line 19: | ||
* Size (WxHxD): 30x30x5mm | * Size (WxHxD): 30x30x5mm | ||
+ | ===== Charger compatibility ===== | ||
+ | The Qi wireless charger expansion deck should work with any Qi-compatible wireless charger pad. It has been tested with an off-the-shelf, | ||
- | ===== Charger compatibility | + | ===== Schematic |
+ | Qi expansion deck {{: | ||
- | The Qi wireless charger expansion board should work with any Qi-compatible wireless charger pad. It has been tested with an off-the-shelf no-name charger pad. | ||
