projects:crazyflie2:expansionboards:zranger [2017-03-14 14:15] tobias [Usage] |
projects:crazyflie2:expansionboards:zranger [2017-03-14 14:20] tobias [Usage] |
Line 20: | Line 20: | ||
The Z-ranger deck will be automatically detected when it is mounted. To activate precise height control press the [[https:// | The Z-ranger deck will be automatically detected when it is mounted. To activate precise height control press the [[https:// | ||
- | Limitations: | + | The sensor can measure distances up to 2 meters but often fails at distances above 1.5m. In case of unreliable readings the Crazyflie 2.0 will slowly descend until reaching a height where measurements are reliable. |
**Note: Currently the mobile clients does not support this functionality!** | **Note: Currently the mobile clients does not support this functionality!** |
