The Z-ranger deck will be automatically detected when it is mounted. To activate precise height control press the altitude hold button on the gamepad and release the thrust. This will “lock” the height as the Crazyflie 2.0 goes into automatic height control mode. The up and down commands will then control the desired height instead of thrust.
Limitations: The sensor can measure distances up to 2 meters but often fails at distances above 1.5m. In case of unreliable readings the Crazyflie 2.0 will slowly descend until reaching a height where measurements are reliable.
