projects:crazyflie:crtp:commander [2013-02-22 07:18] macke created |
projects:crazyflie:crtp:commander [2021-06-24 16:54] (current) kimberly |
| ====== Commander ====== | ====== Commander ====== | ||
| The commander port is used to send control set-points for the roll/ | The commander port is used to send control set-points for the roll/ | ||
| Line 4: | Line 7: | ||
| - | | PITCH | | + | | ROLL | PITCH | YAW |THRUST | |
| - | Length | + | Length |
| ^ Name ^ Byte ^ Size ^ Type ^ Comment ^ | ^ Name ^ Byte ^ Size ^ Type ^ Comment ^ | ||
| - | | PITCH | 0-3 | 4 | float | The pitch set-point | | + | | ROLL | 0-3 | 4 | float | The pitch set-point | |
| - | | ROLL | 4-7 | 4 | float | The roll set-point | | + | | PITCH | 4-7 | 4 | float | The roll set-point | |
| | YAW | 8-11 | 4 | float | The yaw set-point | | | YAW | 8-11 | 4 | float | The yaw set-point | | ||
| | THRUST | 12-13 | 2 | uint16_t | The thrust set-point | | | THRUST | 12-13 | 2 | uint16_t | The thrust set-point | | ||
