The commander port is used to send control set-points for the roll/pitch/yaw/thrust regulators in the Crazyflie. As soon as the communication link has been established these packets can be sent and the values are valid until the next packet is received.
| PITCH | ROLL | YAW |THRUST |
Length 4 4 4 2
| Name | Byte | Size | Type | Comment |
| PITCH | 0-3 | 4 | float | The pitch set-point |
| ROLL | 4-7 | 4 | float | The roll set-point |
| YAW | 8-11 | 4 | float | The yaw set-point |
| THRUST | 12-13 | 2 | uint16_t | The thrust set-point |
