projects:crazyflie:crtp:log [2013-03-20 09:52] macke |
projects:crazyflie:crtp:log [2013-03-20 09:57] macke |
Line 18: | Line 18: | ||
^ **Port** | ^ **Port** | ||
==== Table of content access ==== | ==== Table of content access ==== | ||
- | + | This channel is used to download the Table Of Contents that contains all the variables | |
- | This channel is used to access | + | |
The first byte of each messages correspond a command. All communication on this port are initated by the client and all answer from the copter will contain the same command byte. | The first byte of each messages correspond a command. All communication on this port are initated by the client and all answer from the copter will contain the same command byte. |
