projects:crazyflie:firmware:log [2012-10-07 13:56] arnaud |
projects:crazyflie:firmware:log [2012-10-07 14:18] arnaud |
Line 22: | Line 22: | ||
The first byte of each messages correspond a command. All communication on this port are initated by the client and all answer from the copter will contain the same command byte. | The first byte of each messages correspond a command. All communication on this port are initated by the client and all answer from the copter will contain the same command byte. | ||
- | ^ TOC command byte ^ Meaning | + | ^ TOC command byte ^ Command |
- | | 0 | Get TOC Element | + | | 0 | GET_ITEM |
- | | 1 | Get TOC information | | + | | 1 | GET_INFO |
- | === Get TOC element | + | === Get TOC item === |
+ | The GET_ITEM TOC command permits to retrieved the log variables name, group and types from the copter. This command is intended to be requested from all the ID from 0 to LOG_LEN (see GET_INFO). | ||
Request (PC to Copter): | Request (PC to Copter): | ||
- | | Command | + | | GET_ITEM |
- | Length | + | Length |
Answer (Copter to PC): | Answer (Copter to PC): | ||
^ Request fields ^ Content | ^ Request fields ^ Content | ||
- | | Element | + | | ID |
^ Answer fields | ^ Answer fields | ||
| Type | Variable type of the element. See variable types list | | | Type | Variable type of the element. See variable types list | | ||
| Group | Null-terminated string containing variable group | | | Group | Null-terminated string containing variable group | | ||
| Name | Null-terminated string containing the variable name | | | Name | Null-terminated string containing the variable name | | ||
+ | === Get Info === | ||
+ | The get info command is intended to be requested first when connecting to the copter. This permits to know the number of variable, the limitations of the log implementation and the fingerprint of the log variables. | ||
+ | Request (PC to Copter): | ||
+ | | GET_INFO (1) | | ||
+ | Length | ||
+ | Answer (Copter to PC): | ||
+ | | GET_INFO (1) | LOG_LEN | LOG_CRC | LOG_MAX_PACKET | LOG_MAX_OPS | | ||
+ | Length | ||
+ | ^ Request fields ^ Content | ||
+ | | GET_INFO | ||
+ | ^ Answer fields | ||
+ | | GET_INFO | ||
+ | | LOG_LEN | ||
+ | | LOG_CRC | ||
+ | | LOG_MAX_PACKET | Maximum number of log packets that can be programmed in the copter | | ||
+ | | LOG_MAX_OPS | ||
