Each variable to log is contained in a
| Port | Channel | Function |
| 5 | 2 | Log data access |
| TOC command byte | Meaning |
| 0 | Get TOC Element |
| 1 | Get TOC information |
Request (PC to Copter):
| Command (0) | Element ID |
Length 1 1
Answer (Copter to PC):
| Command (0) | Element ID | Type | Group | Name |
| Request fields | Content |
| Command | Must be 0 for GET_ELEMENT operation |
| Element ID | ID of the element to be retrieved. The variables are numbered from 0 to LOG_LEN (see GET_INFO command) |
| Answer fields | Content |
| Command | 0 for GET_ELEMENT operation |
| Element ID | ID of the element returned |
