Each variable to log is contained in a
| Port | Channel | Function |
| 5 | 2 | Log data access |
Request (PC to Copter):
| GET_ITEM (0) | ID |
Length 1 1
Answer (Copter to PC):
| GET_ITEM (0) | ID | Type | Group | Name |
| Request fields | Content |
| GET_ITEM | At 0 for GET_ITEM operation |
| ID | ID of the item to be retrieved. The variables are numbered from 0 to LOG_LEN (see GET_INFO command) |
| Answer fields | Content |
| GET_ITEM | 0 for GET_ITEM operation |
| ID | ID of the item returned |
| GET_INFO (1) |
Length 1
Length 1 1 4 1 1
| GET_INFO | At 1 for GET_INFO operation |
| GET_INFO | 1 for GET_INFO operation |
| LOG_LEN | Number of log items contained in the log table of content |
| LOG_CRC | CRC values of the log TOC memory content. This is a fingerprint of the copter build that can be used to cache the TOC |
| LOG_MAX_PACKET | Maximum number of log packets that can be programmed in the copter |
| LOG_MAX_OPS | Maximum number of operation programmable in the copter. An operation is one log variable retrieval programming |
