projects:crazyflie:userguide:troubleshooting [2013-05-11 13:30] smiler More detailed reception info |
projects:crazyflie:userguide:troubleshooting [2015-03-01 23:40] fred |
- | ====== Intro ====== | ||
- | Below are some common problems/ | ||
- | ====== Troubleshooting ====== | ||
- | ==== When I try to connect to the quadcopter I get an error and the green LED is not flashing, indicating radio link up ==== | ||
- | This is probably due to a bad radio-connection (using same channel as WiFi?). | ||
- | ==== When I try to take off there seems to be no lift on one/or more motors ==== | ||
- | Most of the time this is either due to the fact that there' | ||
- | If neither helps check that the [[projects: | ||
- | ==== The radio reception is bad and/or I get a lot of Too many packages lost messages ==== | ||
- | If there are other 2.4GHz devices (WiFi, Bluetooth, etc.) around there might be running on the same channel so try switching it in the [[projects: | ||
- | ==== I have broken motors/ | ||
- | There' |
