projects:crazyflie:userguide:troubleshooting
Intro
Troubleshooting
This is probably due to a bad radio-connection (using same channel as WiFi?).
When I try to take off there seems to be no lift on one/or more motors
The radio reception is bad and/or I get a lot of Too many packages lost messages
If there are other 2.4GHz devices (WiFi, Bluetooth, etc.) around there might be running on the same channel so try switching it in the bootloader configuration block. You can also try adjusting the radio bandwidth. If you set it to 250kbit/s you will get good range outside but inside the reception/range might become worse. Since the rate is lower the data spends longer time in the air which increases the probability of interference. Changing the speed to 1Mbit/s or 2Mbit/s will give better results under these circumstances.
I have broken motors/propellers/mounts can I get spare parts?
projects/crazyflie/userguide/troubleshooting.1368271829.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
