projects:crazyflie:userguide:troubleshooting [2013-06-05 10:32] tobias [When I start the Crazyflie the red LED blinks 5 times and I can't fly it?] |
projects:crazyflie:userguide:troubleshooting [2014-03-24 20:38] mark [I'm having problems entering the bootloader mode] Fixed typo |
Line 22: | Line 22: | ||
- | When the PCB arm breaks it breaks it almost always break as in the picture. Since there is a bit of it left it can be used to fix it. | + | When the PCB arm breaks it almost always break as in the picture. Since there is a bit of it left it can be used to fix it. |
Line 62: | Line 62: | ||
Try the following steps: | Try the following steps: | ||
- Power off the Crazyflie | - Power off the Crazyflie | ||
- | - Un-plut and insert the Crazyradio again | + | - Un-plug and insert the Crazyradio again |
- Start the cfclient | - Start the cfclient | ||
- Go to the menu // | - Go to the menu // |
