projects:crazyflie:userguide:troubleshooting
Hardware
When I try to take off there seems to be no lift on one/or more motors?
I have broken motors/propellers/mounts can I get spare parts?
The picture shows the console tab with no errors but when you have an error it might say e.g MPU6050: Self test acc Y [FAIL]. low: 0.300000, high: 0.949999, measured: 0.0. This example means that the accelerometer Y axis didn't pass the self test and is probably defective. It is possible to get 5 blink error also if the Crazyflie is moved to much during the self test, so try putting it on a sable surface before you power it on.
Another thing to try, if you get an accelerometer self test error with measured value 0.0, is to tap/bang it on the sides. E.g. use a table edge to tap/bang it against, and tap/bang the rounded corners of the PCB (where the LEDs are). This could in theory release the accelerometer lock-up. We have had several successful cases doing this and if you managed to fix it this way please let us know.
I broke on of the PCB arms. Is it repairable?
When the PCB arm breaks it almost always break as in the picture. Since there is a bit of it left it can be used to fix it.
Software
The radio reception is bad and/or I get a lot of Too many packages lost messages?
If there are other 2.4GHz devices (WiFi, Bluetooth, etc.) around there might be running on the same channel so try switching it in the bootloader configuration block. You might have to switch a few times fore you find a good one. You can also try adjusting the radio bandwidth. If you set it to 250kbit/s you will get good range outside but inside the reception/range might become worse. Since the rate is lower the data spends longer time in the air which increases the probability of interference. Changing the speed to 1Mbit/s or 2Mbit/s will give better results under these circumstances.
The radio connection is lost after a couple of meter no matter of the channel or datarate?
I'm having strange problems with the sensor test not passing/motors not spinning/horizon not moving when connected?
Try to flash the latest firmware using the instructions here and firmware here.
I upgraded the firmware on the Crazyflie and now it doesn't start
If you get errors during the upgrade or you upgrade to your own custom software that has bugs you might not be able to start the firmware. The typical behaviour for this during power on is that the red/gre LEDs blink and then nothing else happens. No sensor test is run (i.e no more blinking LEDs) and you cannot connect with the Crazyradio.
When upgrading the firmware the bootloader cannot be overwritten or modified so you always have the option of going into bootloader mode and upgrading the firmware again. Here are the instructions for upgrading the firmware.
I'm having problems entering the bootloader mode
Try the following steps:
  1. Power off the Crazyflie
  2. Un-plug and insert the Crazyradio again
  3. Start the cfclient
  4. Go to the menu Crazyflie→Bootloader and click Initiate bootloader cold boot
  5. Power on the Crazyflie (not using USB, only battery) within 1-5 seconds after initiating the bootloader
  6. Flash new firmware without the Verify option enabled
projects/crazyflie/userguide/troubleshooting.1395689924.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
