projects:crazyflie:userguide:troubleshooting [2014-03-24 20:38] mark [I'm having problems entering the bootloader mode] Fixed typo |
projects:crazyflie:userguide:troubleshooting [2021-06-24 16:53] (current) kimberly |
====== Hardware ====== | ====== Hardware ====== | ||
==== When I try to take off there seems to be no lift on one/or more motors? ==== | ==== When I try to take off there seems to be no lift on one/or more motors? ==== | ||
Line 9: | Line 12: | ||
==== When I start the Crazyflie the red LED blinks 5 times and I can't fly it? ==== | ==== When I start the Crazyflie the red LED blinks 5 times and I can't fly it? ==== | ||
- | During the start-up all the mounted sensors run a self test. If either | + | During the start-up all the mounted sensors run a self test. If any of these tests fail, the failure |
The picture shows the console tab with no errors but when you have an error it might say e.g //MPU6050: Self test acc Y [FAIL]. low: 0.300000, high: 0.949999, measured: 0.0.// This example means that the accelerometer Y axis didn't pass the self test and is probably defective. It is possible to get 5 blink error also if the Crazyflie is moved to much during the self test, so try putting it on a sable surface before you power it on. | The picture shows the console tab with no errors but when you have an error it might say e.g //MPU6050: Self test acc Y [FAIL]. low: 0.300000, high: 0.949999, measured: 0.0.// This example means that the accelerometer Y axis didn't pass the self test and is probably defective. It is possible to get 5 blink error also if the Crazyflie is moved to much during the self test, so try putting it on a sable surface before you power it on. | ||
Line 46: | Line 49: | ||
====== Software ====== | ====== Software ====== | ||
==== The radio reception is bad and/or I get a lot of Too many packages lost messages? ==== | ==== The radio reception is bad and/or I get a lot of Too many packages lost messages? ==== | ||
- | If there are other 2.4GHz devices (WiFi, Bluetooth, etc.) around there might be running on the same channel so try switching it in the [[projects:crazyflie:pc_utils:qt_ui# | + | If there are other 2.4GHz devices (WiFi, Bluetooth, etc.) around there might be running on the same channel so try switching it in the [[doc:crazyflie:client:pycfclient: |
==== The radio connection is lost after a couple of meter no matter of the channel or datarate? ==== | ==== The radio connection is lost after a couple of meter no matter of the channel or datarate? ==== | ||
Line 52: | Line 55: | ||
==== I'm having strange problems with the sensor test not passing/ | ==== I'm having strange problems with the sensor test not passing/ | ||
- | Try to flash the latest firmware using the instructions | + | Try to flash the latest firmware using the [[doc:crazyflie:client:pycfclient: |
==== I upgraded the firmware on the Crazyflie and now it doesn' | ==== I upgraded the firmware on the Crazyflie and now it doesn' | ||
If you get errors during the upgrade or you upgrade to your own custom software that has bugs you might not be able to start the firmware. The typical behaviour for this during power on is that the red/gre LEDs blink and then nothing else happens. No sensor test is run (i.e no more blinking LEDs) and you cannot connect with the Crazyradio. | If you get errors during the upgrade or you upgrade to your own custom software that has bugs you might not be able to start the firmware. The typical behaviour for this during power on is that the red/gre LEDs blink and then nothing else happens. No sensor test is run (i.e no more blinking LEDs) and you cannot connect with the Crazyradio. | ||
- | When upgrading the firmware the bootloader cannot be overwritten or modified so you always have the option of going into bootloader mode and upgrading the firmware again. [[projects:crazyflie:pc_utils:qt_ui# | + | When upgrading the firmware the bootloader cannot be overwritten or modified so you always have the option of going into bootloader mode and upgrading the firmware again. [[doc:crazyflie:client:pycfclient: |
==== I'm having problems entering the bootloader mode ==== | ==== I'm having problems entering the bootloader mode ==== |
