User Tools
Site Tools
projects:crazyradio:programming
Differences
Link to this comparison view
Next revision
Previous revision
projects:crazyradio:programming [2013-05-07 16:16]
skube [Radio programming]
projects:crazyradio:programming [2013-05-19 12:17]
macke
Line 1: Line 1:
-====== Radio programming ======+====== Crazyradio firmware upgrade ======
-The Radio dongle can be programmed either via USB bootloader or via <abbr title="Serial Peripheral Interface Bus">SPI</abbr>The USB bootloader does not require any hardware but is **not** currently (as of 2012-09) full-proof (if the flash procedure does not complete well the dongle will have to be reprogrammed via spi)It is recommended to program only released firmware via USB.+**Please note: The current implementation of the bootloader/scripts are not 100% safe. If you upgrade you firmware, make sure that the script says "Verification succeded!" before you unplug the dongle. Other wise you risk "bricking" it (and then it has to be re-programmed via SPI).**
 +**Do not do development and flash you own firmware on the dongle without having access to hardware that makes SPI programming possibleIf firmware that doesn't work is flashed on the dongle you will need to re-program it using SPI**
 +The Crazyradio contains a USB bootloader that gives the possibility to upgrade the firmware without any external hardware (see warnings above)
-In Linux it might be required to launch the commands accessing the USB port as root (ie. with ''sudo'')
 ===== USB bootloader (command line instructions) ===== ===== USB bootloader (command line instructions) =====
 +Please note that you might have to exchange //python// with //python2// if you distro uses python3.
 First Crazyradio has to be rebooted in USB bootloader mode. To do so insert the dongle in the pc, open a terminal window and run the bootloader launcher: First Crazyradio has to be rebooted in USB bootloader mode. To do so insert the dongle in the pc, open a terminal window and run the bootloader launcher:
 <code> <code>
-> cd pc_util/crazyradio/ +> cd crazyradio-firmware
-> python launchBootloader.py +> python usbtools/launchBootloader.py
-Launching bootloader .+Launch bootloader .
-Bootloader launched. +Bootloader started
 </code> </code>
-After running this tool the Crazyradio dongle should have disappeared and a new device named ''nRF24LU1P-F32 BOOT LDR'' should appear.+After running this tool the Crazyradio dongle should have disappeared and a new device named **nRF24LU1P-F32 BOOT LDR** should appear.
 To flash the firmware use the nrfbootload.py script: To flash the firmware use the nrfbootload.py script:
 <code> <code>
-> python nrfbootload.py flash /path/to/cradio.bin+> cd crazyradio-firmware
 +> python usbtools/nrfbootload.py flash cradio-0.51.bin
 +Found nRF24LU1 bootloader version 18.0
 +Flashing:
 +  Flashing 5771 bytes...
 +Flashing done!
 +Verifying:
 +  Reading cradio-0.51.bin...
 +  Reading 5771 bytes from the flash...
 +Verification succeded!
 +</code>
 +===== Step-by-step upgrade using the Bitcraze VM =====
 +Below is a short guide with step-by-step instructions on how to upgrade the Crazyradio with the latest firmware using the [[projects:virtualmachine:index|Bitcraze VM]]
 +  * Start up the VM and download the latest firmware from [[https://bitbucket.org/bitcraze/crazyradio-firmware/downloads|here]] (currently v0.51). Place the firmware in **/home/bitcraze/projects/crazyradio-firmware**
 +  * Open up a terminal
 +  * Insert the Crazyradio and pass it to the VM
 +  * Run the following commands:
 +  * <code>
 +> cd ~/projects/crazyradio-firmware
 +Bootloader started
 +</code>
 +  * Once the bootloader is started the Crazyradio dongle will dissapear ad a new device named **nRF24LU1P-F32 BOOT LDR** will appear. Pass this to the VM.
 +  * Run the following command:
 +  * <code>
 +Flashing:
 +Flashing done!
 +Verifying:
 </code> </code>
 +  * If you see **Verification succeded** then unplug the dongle and re-insert it again. If you do not see this message, but instead some error. Do **NOT** unplug the dongle, try to reflash the firmware instead.
projects/crazyradio/programming.txt · Last modified: 2020-05-12 14:13 by kimberly
