projects:crazyradio:programming [2013-05-07 16:16] skube [Radio programming] |
projects:crazyradio:programming [2013-05-14 09:19] arnaud [USB bootloader (command line instructions)] |
====== Radio programming ====== | ====== Radio programming ====== | ||
- | The Radio dongle can be programmed either via USB bootloader or via SPI. The USB bootloader does not require any hardware but is **not** currently (as of 2012-09) full-proof (if the flash procedure does not complete well the dongle will have to be reprogrammed via spi). It is recommended | + | The Radio dongle can be programmed either via USB bootloader or via SPI. The USB bootloader does not require any hardware but is **not** currently (as of 2012-09) full-proof (**if the flash procedure does not complete well the dongle will have to be reprogrammed via spi**). Unless you have equipment |
- | In Linux it might be required to launch the commands accessing the USB port as root (ie. with '' | + | In Linux it might be required to launch the commands accessing the USB port as root (ie. with '' |
Line 9: | Line 9: | ||
- | > cd pc_util/crazyradio/ | + | > cd crazyradio-firmware |
- | > python launchBootloader.py | + | > python |
- | Launching | + | Launch |
- | Bootloader | + | Bootloader |
Line 21: | Line 20: | ||
- | > python nrfbootload.py flash /path/to/cradio.bin | + | > cd crazyradio-firmware |
+ | > python | ||
+ | Flashing: | ||
+ | Flashing 5771 bytes... | ||
+ | Flashing done! | ||
+ | Verifying: | ||
+ | Reading cradio-0.51.bin... | ||
+ | Reading 5771 bytes from the flash... | ||
