The Radio dongle can be programmed either via USB bootloader or via SPI. The USB bootloader does not require any hardware but is not currently (as of 2012-09) full-proof (if the flash procedure does not complete well the dongle will have to be reprogrammed via spi). It is recommended to program only released firmware via USB.
In Linux it might be required to launch the commands accessing the USB port as root (ie. with sudo
> cd pc_util/crazyradio/ > python launchBootloader.py Launching bootloader .. Bootloader launched. >
After running this tool the Crazyradio dongle should have disappeared and a new device named nRF24LU1P-F32 BOOT LDR
should appear.
> python nrfbootload.py flash /path/to/cradio.bin
