projects:crazyradio:programming [2013-05-11 19:22] macke |
projects:crazyradio:programming [2013-05-14 09:19] arnaud [USB bootloader (command line instructions)] |
====== Radio programming ====== | ====== Radio programming ====== | ||
- | The Radio dongle can be programmed either via USB bootloader or via SPI. The USB bootloader does not require any hardware but is **not** currently (as of 2012-09) full-proof (if the flash procedure does not complete well the dongle will have to be reprogrammed via spi). It is recommended | + | The Radio dongle can be programmed either via USB bootloader or via SPI. The USB bootloader does not require any hardware but is **not** currently (as of 2012-09) full-proof (**if the flash procedure does not complete well the dongle will have to be reprogrammed via spi**). Unless you have equipment |
- | In Linux it might be required to launch the commands accessing the USB port as root (ie. with '' | + | In Linux it might be required to launch the commands accessing the USB port as root (ie. with '' |
Line 21: | Line 21: | ||
> cd crazyradio-firmware | > cd crazyradio-firmware | ||
- | > python usbtools/ | + | > python usbtools/ |
Found nRF24LU1 bootloader version 18.0 | Found nRF24LU1 bootloader version 18.0 | ||
Flashing: | Flashing: | ||
Line 27: | Line 27: | ||
Flashing done! | Flashing done! | ||
Verifying: | Verifying: | ||
- | Reading | + | Reading cradio-0.51.bin... |
Reading 5771 bytes from the flash... | Reading 5771 bytes from the flash... | ||
Verification succeded! | Verification succeded! | ||
