projects:crazyradio:programming
Radio programming
The Radio dongle can be programmed either via USB bootloader or via SPI. The USB bootloader does not require any hardware but is not currently (as of 2012-09) full-proof (if the flash procedure does not complete well the dongle will have to be reprogrammed via spi). It is recommended to program only released firmware via USB.
USB bootloader (command line instructions)
> cd crazyradio-firmware
> python usbtools/launchBootloader.py
Launch bootloader .
Bootloader started
> python usbtools/nrfbootload.py flash firmware/bin/cradio.bin
Found nRF24LU1 bootloader version 18.0
Flashing:
  Flashing 5771 bytes...
Flashing done!
Verifying:
  Reading firmware/bin/cradio.bin...
  Reading 5771 bytes from the flash...
Verification succeded!
projects/crazyradio/programming.1368292927.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
