| projects:crazyradio:programming [2013-05-07 16:16] skube [Radio programming] | projects:crazyradio:programming [2020-05-12 14:13] (current) kimberly | ||
| - | ====== Radio programming ====== | + | <WRAP center round important 60%> |
| - | The Radio dongle can be programmed either via USB bootloader or via <abbr title=" | ||
| - | In Linux it might be required | + | ====== Crazyradio firmware upgrade ====== |
| + | **Please note: The current implementation of the bootloader/ | ||
| + | **Do not do development and flash you own firmware on the dongle without having access | ||
| + | The Crazyradio contains a USB bootloader that gives the possibility to upgrade the firmware without any external hardware | ||
| ===== USB bootloader (command line instructions) ===== | ===== USB bootloader (command line instructions) ===== | ||
| + | Please note that you might have to exchange //python// with //python2// if you distro uses python3. | ||
| First Crazyradio has to be rebooted in USB bootloader mode. To do so insert the dongle in the pc, open a terminal window and run the bootloader launcher: | First Crazyradio has to be rebooted in USB bootloader mode. To do so insert the dongle in the pc, open a terminal window and run the bootloader launcher: | ||
| - | > cd pc_util/crazyradio/ | + | > cd crazyradio-firmware |
| - | > python launchBootloader.py | + | > python |
| - | Launching | + | Launch |
| - | Bootloader | + | Bootloader |
| - | After running this tool the Crazyradio dongle should have disappeared and a new device named '' | + | After running this tool the Crazyradio dongle should have disappeared and a new device named **nRF24LU1P-F32 BOOT LDR** should appear. |
| To flash the firmware use the nrfbootload.py script: | To flash the firmware use the nrfbootload.py script: | ||
| - | > python nrfbootload.py flash /path/ | + | > cd crazyradio-firmware |
| + | > python | ||
| + | Found nRF24LU1 bootloader version 18.0 | ||
| + | Flashing: | ||
| + | Flashing 5810 bytes... | ||
| + | Flashing done! | ||
| + | Verifying: | ||
| + | Reading cradio-pa-0.53.bin... | ||
| + | Reading 5810 bytes from the flash... | ||
| + | Verification succeded! | ||
| + | </code> | ||
| + | ===== Step-by-step upgrade using the Bitcraze VM ===== | ||
| + | Below is a short guide with step-by-step instructions on how to upgrade the Crazyradio with the latest firmware using the [[projects: | ||
| + | * Start up the VM and download the latest firmware from [[https:// | ||
| + | * Open up a terminal | ||
| + | * Insert the Crazyradio and pass it to the VM | ||
| + | * Run the following commands: | ||
| + | > cd ~/projects/ | ||
| + | > python usbtools/ | ||
| + | Launch bootloader . | ||
| + | Bootloader started | ||
| + | * Once the bootloader is started the Crazyradio dongle will dissapear ad a new device named **Nordic Semiconductor nRF24LU1P-F32 BOOT LDR** will appear. If you do not have a filter set up for the bootloader in the VM then script will say that it failed. This is ok. Pass the bootloader device into the VM and continue. | ||
| + | * Run the following command: | ||
| + | Flashing: | ||
| + | Verifying: | ||
| + | * If you see **Verification succeded** then unplug the dongle and re-insert it again. If you do not see this message, but instead some error. Do **NOT** unplug the dongle, try to reflash the firmware instead. | ||
| + | ===== Check your firmware version ===== | ||
| + | Run the following command: | ||
| + | > lsusb -d 1915:7777 -v | grep bcdDevice | ||
| + | This should return the version (e.g. " | ||
