projects:crazyradio:programming [2013-05-11 19:24] macke |
projects:crazyradio:programming [2015-01-07 11:58] macke |
- | ====== Radio programming ====== | ||
- | The Radio dongle can be programmed either via USB bootloader or via SPI. The USB bootloader does not require any hardware but is **not** currently (as of 2012-09) full-proof (**if the flash procedure does not complete well the dongle will have to be reprogrammed via spi**). It is recommended to program only released firmware via USB. | ||
- | In Linux it might be required to launch the commands accessing the USB port as root (ie. with '' | ||
- | ===== USB bootloader (command line instructions) ===== | ||
- | First Crazyradio has to be rebooted in USB bootloader mode. To do so insert the dongle in the pc, open a terminal window and run the bootloader launcher: | ||
- | > cd crazyradio-firmware | ||
- | > python usbtools/ | ||
- | Launch bootloader . | ||
- | Bootloader started | ||
- | After running this tool the Crazyradio dongle should have disappeared and a new device named '' | ||
- | To flash the firmware use the nrfbootload.py script: | ||
- | Found nRF24LU1 bootloader version 18.0 | ||
- | Flashing: | ||
- | Flashing 5771 bytes... | ||
- | Flashing done! | ||
- | Verifying: | ||
- | Reading firmware/ | ||
- | Reading 5771 bytes from the flash... | ||
- | Verification succeded! | ||
