The Radio dongle can be programmed either via USB bootloader or via SPI. The USB bootloader does not require any hardware but is not currently (as of 2012-09) full-proof (if the flash procedure does not complete well the dongle will have to be reprogrammed via spi). It is recommended to program only released firmware via USB.
> cd crazyradio-firmware > python usbtools/nrfbootload.py flash firmware/bin/cradio.bin Found nRF24LU1 bootloader version 18.0 Flashing: Flashing 5771 bytes... Flashing done! Verifying: Reading firmware/bin/cradio.bin... Reading 5771 bytes from the flash... Verification succeded!
