projects:crazyradio:python_lib [2015-08-06 12:10] arnaud |
projects:crazyradio:python_lib [2015-08-06 12:18] arnaud |
Line 18: | Line 18: | ||
- | Ths is an example on how to use the lib: | + | This is an example on how to use the lib: |
<code python> | <code python> | ||
Line 53: | Line 53: | ||
^ Returns | ^ Returns | ||
^ Description | Close the USB device. Should be called before closing the program. | | ^ Description | Close the USB device. Should be called before closing the program. | | ||
- | == set_channel(self, | ||
- | ^ Name | '' | ||
- | ^ Parameters | ||
- | ^ Returns | ||
- | ^ Description | Set the Crazyradio channel. Channel must be between 0 and 125. Channels are spaced by 1MHz starting at 2400MHz and ending at 2525MHz. | | ||
== set_channel(self, | == set_channel(self, |
